S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Rear brake pad change question.
Old 07-25-2014, 12:05 PM
SpeedTriplemark's Avatar
Default Rear brake pad change question.
My question is operational to those who have changed rear pads.
Before I attempt tonight, I checked YouTube for Ross-tech Vag-Com video and only found procedure for an A6.
Ross-tech strongly encourages to use a battery charger, but suggests different areas to hook-up depending on car model. (System charge vs. direct battery charge). No mention of B8-S4s.
Those who have used Vag-com on S4s: Did you connect directly to battery terminals (in trunk), or "somewhere else" ?
Old 07-25-2014, 01:28 PM
kczach's Avatar
I used the positive terminal under the hood and a frame ground.
Old 07-25-2014, 01:41 PM
Where is this "positive terminal under hood"? Battery is located in trunk by spare tire, right?
Thanx.
Old 07-25-2014, 02:15 PM
RobC's Avatar
Under the hood on the passenger side near the firewall there should be a cap marked with a plus (+) sign. That's where you connect to jump start the car. There should be a negative post nearby.
RobTheAudiOwner
Q5/SQ5 MKI (8R) Discussion
07-24-2017 11:59 AM
jeguzik
06-18-2012 05:35 AM
|barTok|
05-17-2007 02:54 AM
f3d
02-24-2005 09:19 PM
javery42
08-20-2003 01:13 PM
Quick Reply: Rear brake pad change question.
