Anyone install radar yet?
#21
And REALLLLLY disappointed today to find out that even hard-wiring/tapping the mirror did NOT resolve the issue of the engine auto/start/stop cutting off power to the radar unit, and subsequently restarting the radar EVERY single time!!
I was hoping moving the power source from the cigarette lighter would resolve this.
I can't believe NOBODY else has mentioned or complained about this malady??
I'm now VERY interested in permanently defeating this stoopid "feature".
gr
gr
#23
gr
gr
yes, my Valentine does the same thing, which is a pain in the butt. Please let us know what the fix is, once you figure it out.
#24
I paid special attention to my dashcam today while driving, and it does not cut out when the auto stop kicks in. It switches on and off with the ignition as expected. I picked up the yellow and brown wires in the connector that goes back toward the headliner, as my mirror taps fit better in that connector than the one on the mirror. Not sure if that makes a difference or not?
#25
http://www.valentine1.com/v1info/bob.asp
So my radar detector only turns off when I shut the car off.
#28
So, I wanted to post this up - as I had a bit of an odd problem pop up with my install of mirror tap and radar detector.....
About a month ago, I upgraded to a Uniden R3 from my 10 year old Bel RX65. Very awesome unit....I highly recommend!
However, a few days after the switch, I noticed that my mirrortap power cord wasn't powering the R3 any longer, and then I noticed that the compass in the RV mirror was out as well.
Odd, but naturally, I figured it was a blown fuse - and I suspected it was due to the short length of the mirror-tap wire, and having to mount the R3 in a defferent position than the Bel.
So, I finally took apart the upper mirror mount last night, but couldn't find any relative reason for the blown fuse: everything was as it should be, and no frayed wires or dislodged taps in the mirror harness.
I know that the power cord for bel and uniden is similar enough to be able to share connectors, so I'm slightly stumped as to what could have caused it???
A RD unit draws current in MicroVolts, so I know it's not the draw on the circuit. I was surprised to find that the circuit that feeds the Rearview mirror also ties into the rear A/C system, something to do with climate control, and couple other accssory systems. All of which are only fused by a 5 amp fuse. That seems low to me for ALL of those components.
I did resolve, however, that for now, I am removing the wire tap from the RV mirror, and using my coiled power cord. With suction cup mount.
I dont like leaving the RD in the baking sun all the time anyway, so i usually take it down when parking anywhere in public -- so no need for stealth.
Just FYI. If I ever figure out the cause, I'll post up.
I suspect it's a mismatch with the mirror tap wire and the Uniden unit.....as unlikely as it seems, but I have no other explanation at this time.
gr
gr
#29
https://www.youtube.com/watch?v=FVfcRy6GY-s&t=40s
gr
gr
