Dynamic idle vs auto or comfort
So one thing I noticed
when I was tinkering in my garage with my new EPIC s4.
the idle is higher by3-400rpm in dynamic and the car is in park
im curious
why does That happen ?
chris
im curious
chris
To spool the turbo quicker off the line. It puts the idle rpm close to where the turbo starts building boost once you step on the throttle, for virtually no lag off the line.
Firstly, the car can only be in S mode because the driver chose put it there, either via using the transmission shifter or cycling through the MMI modes. It will never start in S mode. So it idles in Park at higher RPM because that's how the driver set the engine/transmission map.
And the car is using a B-cycle engine, with variable valve timing depending on whether it is in B-cycle or Otto cycle. When in D mode, the car will run in B-cycle whenever it can depending on engine load and RPM. In B-cycle, it makes more torque below boost, and so runs a lower idle speed. It will transition from B-cycle to Otto cycle at specified engined speeds and loads. In S mode, IMO (Audi do not publish any specifics other than in their patents) the engine is never in B-cycle, so it has less torque below boost, therefore idles closer to boost (1370rpm) to avoid a torque hole.
thank you
Wow cool. i had no idea the car had two engine profiles.
thank you for the explanation.
no to sound like to big of a noob. but is there anyway to get another 40 horses or so out of this car without voiding the warranty.
i just cant hold back....
thanks
c
thanks
c
I happen to think it's pretty brilliant. I get 31mpg on the highway but still put down 354hp/369tq to four wheels via a full time mechanical AWD system. That's extremely impressive, and represents a 3mpg improvement with a power bump and torque available wayyyyy lower than the previous S4.
Depends where you live. Not in North America, as per mplsbrian's reply. But your car sounds new, it will open up more at around 1k miles.
