Matrix LED Headlights, camera and coding?
I am very familiar with this technology. My M4 has the LED headlights which have been coded to fully enable the anti-dazzle feature. Before coding, the LEDs were nice but not a significant improvement over the standard Xenons. Post coding, wow!
The matrix LEDs are a different headlight front the "regular" LED headlights. You'd have to order the headlights from Europe and install them along with the correct coding. I believe they use the existing camera that's used for the high beam switch.
It's been discussed but I don't know of anyone who has done it.
Audi do not fit matrix LED headlights as standard anywhere, including Germany. It is not a case of the USA getting the matrix LEDs with the function turned off due to legislation.
As an option upgrade over standard LED, it is not particularly expensive - ~$600. To buy the units as a replacement part, and do whatever else is needed to get them working, very expensive.
The advanced systems, as I am sure you know, use a larger number of LED emitters, with a narrower beam as determined by the discrete reflectors used. This enables these individual (but overlapping) beams to be either blanked or dimmed as the system deems fit. I have it on my B9 S5, but all my night driving to date has been in urban environments, so to be honest I don't notice any difference. The most obvious benefit is that I just keep my lights set to Auto, and never have to touch any switch again - the system does everything itself.
My A7 had LED lights with the auto-dimming feature, but I found it too slow to react and never used it. The technology is improving all the time.
Believe me, I've got plenty of blame to go around. This time I picked on the IFG specifically because it was topical to the DOT fiefdom.
As for Matrix, no. The standard LED lamps are different internally, including the beam pattern, color temperature, and lumen output on NAR housings.
