is 18x9 wheels et 35mm recommended?
You'll likely experience rubbing ...
Many here experience minor contact up front when turning under compression with just an 8" wide rim and ET35 offset. Plus, you'll want to run at least 235 rubber, 245 or 255 would be even better suited to a 9" width, and those would definitely require rolling the fenders ... and even that might not be enough.
will 8.5in wide wheels rub? if not, what offset is ideal to set as flush to the fenders as possible?
bla4ck
10-20-2005 10:46 PM
LoSz
09-08-2005 07:26 PM
mpwolf
10
12-09-2003 06:57 AM
n_r_child
05-09-2003 10:10 AM
