710A vs. 710N..how much "more" vacuum pressure to open up 710N?
Granted a very "non-scientific" test but on the 710A (stock) I could suck on the vacuum nipple and open up the valve...however on the 710N I could not..is this just due to the increased spring rate of the 710N? Or does it require more pressure and time to open up the 710N...I have see posts but none on vacuum pressure...
Also what is the "advantage" of a large piston displacement of the 710N?
Re: 710A vs. 710N..how much "more" vacuum pressure to open up 710N?
Check the graph from the BPV test at the link below. And dude, I hope you at least cleaned those things before your test!<ul><li><a href="http://www.s4biturbo.com/art-dvtests.shtml">http://www.s4biturbo.com/art-dvtests.shtml</a</li></ul>
Stop sucking on the nipples ...
and read Mike's article. 8^P
Seriously though, regurgitating what he wrote:
<I>"it looks as if the 110/710N will take a longer time to open, but, just because it comes open a few in. of Hg later, the typical vacuum pressure developed can be ten times this difference. So there should be no worries with a slow response time with any of these Bosch valves."</I>
PKmode
20
03-31-2006 06:08 AM
back2black
09-27-2004 10:21 AM
ImolaRocket
07-03-2004 06:13 PM
back2black
05-02-2004 01:14 PM
