ABS Control Unit - Which is the correct part #?
The original part only lists the Bosch Part Number 0 273 004 284, but that doesn't come up on the computer. Instead, it lists all the following part numbers for an "S4 Q Twin Turbo V6 00-02"
0 265 202 403 (ABS Control Unit)
1 273 004 284 (ABS Control Unit)
8E0 614 111E (ABS Control Unit)
8E0 998 375 (ABS Control Unit Repair Kit)
I have a 2000 S4 with Steel uprights.
there should be a letter at the end of all of the numbers... there are a bunch of different ones so
be sure... although i think the last one 375 is correct, you just need to make sure the letter at teh end is the same.
