actual vs. requested: actual = consistent 2.5-3psi lower. thoughts?
<center><img src="http://pictureposter.audiworld.com/37814/boost.jpg"></center><p>Hi All,
Not a full 3rd gear run but perhaps enough to get some opinions (will be doing more logging in the coming week).
Two things: I'm investigating why I'm not peaking/hodling even requested as high as it used to be - - this has been the case ever since I received updated GIAC file.
But mainly for this post: I'm curious about my actual - - it's not dying off, but holding steady 2.5-3psi below requested. Seems like it should be a lot closer to requested? Would that still sound like a boost leak if it's not continuing to drop and drop as rpms and requested go up/stay constant?
TIA,
Per
TIA,
Per
Welcome to the club! Looks like a boost leak. Log 118 to confirm - WG DC should be in high 90's
trying to compensate for the loss of pressure and if it's the case, you have a huge boost leak somewhere.
I can borrow you all the necesary pressure testing stuff. Let me know.
My guess is a leak as well. This is what a healthy 115 log looks like.
<center><img src="http://pictureposter.audiworld.com/92770/boostcurve-82f.jpg"></center><p>It's stock but the actual and requested are pretty much dead on.
my bad N75 looked the same.
<img src="http://i26.photobucket.com/albums/c125/drewski11/N75%20Difference/image002.gif">
