Advise needed. I'm in the process of cleaning and regreasing my neuspeed sway bar bushings.........
Is there anything else that I should apply grease to while I'm at it?
btw, I'm using Marine Grease (Quicksilver Multipurpose 2-4-C Marine Lubricant with Teflon).
-Anthony-
Note: I'm aware that I still have to finish tightening the bushing collar bolts.
<img src="http://i3.photobucket.com/albums/y61/TonyCat/ef5fdc46.jpg">
<img src="http://i3.photobucket.com/albums/y61/TonyCat/2c570421.jpg">
-Anthony-
Naturally, a cold (36 deg.) rain started to fall as I was doing the otherside, but............
I persevered and finished the job. Took the car out for a test drive. No more squeeking from the bushings. It's peaceful, quiet bliss again. :-)
What is a zerks? Is it a grease fitting/nipple? and if so, for it to work, do you have to...........
cut grooves in the I.D. of the bushing or just loosen the bushing retainer/clamp/collar to allow the grease to flow all around the I.D.?
