any s4 owners in bergen county nj have a VAG?!! Just installed nav plus.. TMC isnt working
oh, I forgot to mention, some cars have no connection between the radio and the cluster....
That says tells you:
"In some 2001 cars, Audi either did not connect the CAN wires on the back of the radio, or if they did, they don't go anywhere. It's worth trying first. If you have orange CAN wires, you are probably OK. If they are grey, you will likely have to remove your cluster to run wires.
Cluster Pin # TMC Pin # Comment
Grey Connecter Pin 5 TMC Pin 3 CAN H
Grey Connecter Pin 6 TMC Pin 2 CAN L
If you need pins for the cluster, they are part number 000 979 003. Removing the cluster is fairly easy, so don't be put off by the idea."
FWIW, I needed to put new pins into one of the connectors on back of the cluster.
stupidrobothead
VAG-COM Discussion
08-21-2003 05:34 AM
Jacce1971
07-15-2003 06:07 AM
BLou R32-Bmore
09-06-2002 10:09 AM
