Any shops on here or anyone in gerneral know how to remove this stripped bolt?
<center><img src="http://i223.photobucket.com/albums/dd89/s4inlowplaces/CARMOTOROUT.jpg?t=1201654521"></center><p>So i tried hammering a bigger socket into it and it dint work, tried getting a dremel in there to maybe grind down the sides so that i codl put a socket over it but big bolt in the middle dosent give enough space. ALso tried dremeling out a slot so that i coudl use a big flat head in there but could get the dremel in at all. What should i do?
buy a torx and bit it in there slowly or the bolt out kit
those bolts shouldn't have much torque in them ..spray some liquid wrench or free all before going further.
<img src="http://www.chromate.com/NC%20STATE%20CONTRACT/952166.jpg">
Guest
Posts: n/a
The reason they strip, usually, is crud in the bolt head
keeps the allen from seating all the way in.
At this point, I would hammer a torx socket into the bolt head.
Spend more time hammering than you think you need. Doing this will help the threads break free.
I keep those bolts in stock and usually replace them with every TB I do.
