Anybody have a metallic rattle under the hood around 1000-1100 rpm? Dealer said it's "normal" .
I had the same around 2500, turned out to be a heat shield on one of the turbos.
01 Onyx/Silver
3000mi 4 trips to the dealer
3 different steering wheels
One loose heat shield
Faulty instrument cluster
Faulty door/light charm
4 days in a Malibu
4 days in a Malibu
probably the heat shields....more
Loose heat sheilds seem to be pretty common....i had them.....
also had a metallic "chirping" (kinda like a cricket) at certain rpm/loads...that ended up being one of the wastegate rods contacting a heat sheild.....tech "adjusted" the heat sheild to prevent this...
last but not least....the most nagging of all and i complained several times about it....they finally found it at my 8k service....a broken weld on one of the exhaust manifolds (caused a rattle between 2k and 3k rpm)....this one required an engine pull to fix but its finally fixed!!!!
hope this helps
David White
2000 Silver S4 (rattle free at last)
hope this helps
David White
BiturboA6
09-20-2010 11:03 AM
Raistlin
A4 (B7 Platform) Discussion
08-06-2007 05:21 PM
|skolnick
01-16-2007 02:25 PM
DisTTracted
07-24-2005 09:37 PM
.357
04-10-2004 02:45 PM
