anyone ever seen/heard of anyone using these brakes in a b5s4? they look like awful overkill
Old 09-26-2005, 01:12 PM
  #21
ryans4's Avatar
Default i'm on a mission to prove that...
...$1k is all you need to spend for a suspension.
Come down to pahrump, they're expanding it, new layout looks fun.
Old 09-26-2005, 01:49 PM
  #22
Imolavirus@BuehnEngineering's Avatar
Penske's rule all
Old 09-26-2005, 02:01 PM
  #23
New Member
Silver Arrow 14's Avatar
Default on pads -...
Ryan - finally got to the pagid setup we talked about long time ago - 4-4 orange front/4-2 blue rear...tracksport setup...not onlybhad to have the front 1595 machined...filed...but also found rear needed some work...there was a tall tab on 3242 that I needed to file and bend away from contact with caliper or is the 1158 a better fit...
http://www.pagidusa.com/btcontents.htm
brake pad drawing index
take a look at the 1158, and then the 3242 at link
wadday think?
Old 09-26-2005, 02:53 PM
  #24
ryans4's Avatar
Default i'm running 1158s on my car, but they didn't come with spring clips...
...had to take those off the old pads, and it's a little bit of a ghetto smash up install, but it works and they don't rattle around.
Old 09-26-2005, 03:45 PM
  #25
s4gonebabygone's Avatar
haha yea. its kind of a pain when the brakes get squishy before the tires heat up though
Old 09-26-2005, 03:47 PM
  #26
Default what's your setup?
springs and a stiff rear bar pobably get you 90% of the way
Old 09-26-2005, 04:04 PM
  #27
ryans4's Avatar
Default i'm still changing. my current setup is great, but too low...
...Eibach pro system on stock bars.
Great on track, comfortable enough on the street, but it's entirely too low ground clearance wise. In addition, it'll push when you hit dips loaded (needs more travel), but in normal cornering (no dips), it's very neutral.
Old 09-26-2005, 07:35 PM
  #28
Default thats cool. i ran on H&R ultras with stock bars and found it pushing too much.
im on H&R ultras with H-Sport swaybars on stiff and cpp/asp links rear/front. this setup is really awesome. i cant imagine having the need for a more advanced setup suspension-wise. i am planning on upgrading brakes over this offseason though.
Old 09-26-2005, 08:33 PM
  #29
New Member
Default ghetto smahup I can relate to ...had to remove, "modify", and reinstall
the ones I had (3242)...filed, bent, not spring currently...and yes...I hear the outboard ones talking to me...OBTW the rotors in front are not wearing to the top...remember the hat/backing plate concern, and now the top of the rotor appears unscathed, and the wear is digging a trench in the rotor face [overstated]...that okay, or should I do something about it???...started with SBS, now Pagids - some cut to hang even lower than SBS...
JerryS4
05-23-2010 09:13 AM
fa590
Audi A3 / S3 / RS 3
15
03-09-2006 03:33 AM
asTTro boy
23
02-18-2004 08:28 AM
Krisko
Florida Discussion
12
03-14-2003 09:58 AM
Another Drew
13
05-07-2001 01:11 PM
Quick Reply: anyone ever seen/heard of anyone using these brakes in a b5s4? they look like awful overkill
