Anyone ever use Langka to remove paint chips?
Yes, but...
Langka doesn't remove chips. You use it to make areas that have been touched up flush with the surrounding paint.
If you're the **** type that likes to put on 3 layers of primer, then 4 layers of touch-up paint with sanding, etc., taking 3 days to fix a chip then Langka isn't for you.
I've gotten very good results with it. It's basically a very mild paint solvent that doesn't attack cured paint. You clean and touch-up the chip, let it dry for 2-8 hours depending upon temp and humidity, then use Langka on a cloth to gently smooth the touch-up spot to be flush with the surface. Much less risky than trying to sand a spot flush.
A4 to A8
08-11-2009 09:00 PM
RickM
Auto Detailing Discussion
10
04-29-2007 08:29 AM
