Anyone know how to get under the dash?
The black plastic under the dash looks like it is held in with the white clip near the clutch and should slide out, but doesn't seem to. The Bentley manual doesn't seem to be much help.
Thanks!
Thanks!
It's part of the main dash under sterring wheel. One piece.,
Check out this url to see how to pull the lower dash piece out.<ul><li><a href="http://home.pacbell.net/tmblue/defi_hud_install.htm">http://home.pacbell.net/tmblue/defi_hud_install.htm</a</li></ul>
You need to remove the small, rectangular covers to the lower left and right of the steering column.
Use a small screwdriver to pop them out. Under the covers are two 8mm bolts that must be removed. Also, there is a bolt near the fuse panel.
Scott_Napier
Audi Original "S" Cars
04-15-2009 12:54 PM
E-Ticket
05-07-2000 06:21 PM
