Best path to run power wire to truck for sub?
I haven't popped apart anything yet, just looked under the hood and wondered, what's going to be the best way to get through the firewall and then back to the truck?
Folks who have done this what is the "cleanest" way to hide the wire.
Thanks,
Chris
'00 w/tip
Thanks,
Chris
'00 w/tip
If you parked the truck anywhere close to your trunk (or otherwise behind your firewall)...
...you probably should run it near the ECU housing. I've seen lots of pics of this. Dig through the Audio forum for more details.
Re: Best path to run power wire to truck for sub?
Through the rubber nipple on the box that houses the ecu, down through the hole in the bottom of the ecu housing, behind the LH kick panel, under the LH door sills, up under the rear seat then to your destination.<p>donp - '00 S4 Silver/Silver
audizone.com
I followed the brake lines with 2 1 guage welding cables. Back in under the back seat
<p>Jim De Arras
<a href="http://www.imola.org">2000 00 Imola/Onyx/Alcantera S4</a>
MTM Stage II (Stage III on order)
MTM Full Suspension
MTM/Pagid Brake pads
UUC Short Shifter (original 20%)
Michelin Pilot Sports.
SmartTire Tire Monitor
MTM Full Suspension
With all the talk about what's wrong with S4, here's a lil' story to remind you why you bought it.=)
frank
09-06-2000 06:11 PM
silvertip
08-05-2000 10:55 PM
NASA racer
07-31-2000 07:19 AM
Jim De Arras
25
07-05-2000 02:12 PM
