Bi-Amp for Bi-Turbo, am I the only one?
Guest
Posts: n/a
Yeah, but you'd have to use one on the left and one on the right
I've already got 2 Orion 225-HCCA's that I've had for a while; I'll probably use those (too bad they're red and I've got Nogaro blue coming); but I'm not hooking them up left/right either, rather subs and full-range.
Guest
Posts: n/a
Re: Bi-Amp for Bi-Turbo, am I the only one?
If I were to go multi amps I would use 3 PC440's in 2 channel mode on a Dyne three way set up front, and an PC1800 or PC21400 on a pair of PPI Pro12's. But I dont want to weight down my car that much. I am trying to keep it simple but who knows.
Andrew
Andrew
Guest
Posts: n/a
Yikes, I used to cook hot dogs on the heat sinks of the 225's
Back when I competed in Car Stereo gang wars I used Orions and then Pheonix Gold amps. The PG amps were far more stable, I had an Orion 425HCCA amp that used to melt fuses. Of course when you run them at 1 ohm....
Ryan in T.O.
Canadian Discussion
02-16-2009 11:17 AM
A4xIV / Nadroj
03-23-2004 04:18 PM
T-28-Quattro de VT
04-13-2002 01:06 PM
