Biggest spare tire that fits in Avant tire well?
I'd like to replace the doughnut spare tire with a real tire. Will a stock S4 rim fit in the spare tire well? If not, what is the largest "real" tire that will fit in there? Even something like a 205/55R16 would be a lot better than a doughnut in case of a flat tire--if it clears the brake, of course.
TIA.
TIA.
I have tried to put an AVS sport that was 235-45 on an Avus wheel, and it was too tall
to fit in the well. Daphne has installed a stock tire with no problem. So I guess that is the biggest you cna get in there.
You cna either cut the bar or use a torx 15? IIRC to remove the plastic.
But then you still have to pull up the metal retainer springs. It is a PITA, but worth it for how often you think you will ever use the spare.
Actually, no spring is removed
The rear metal & plastic thing is held by 2 torx screws. Remove it by easing it off.
Without cutting anything away, you have a bit of an angle getting the spare in and out, but as you say, how often do you really use the spare.
Think he is talking about those 2 little silver clips that lock in towards
the center. Did you happen to cut yours? If so, could you post a pick? I have been tempted whenever rotating tires but don't want to cut if it looks gheto.
Well, never, until a few weeks ago.
Based on that experience, I'd like to have a full-size, or at least a real, spare tire, rather than the doughnut.
Thanks for the info.
Zwoobah
08-01-2007 09:10 AM
HDClown
09-10-2001 11:55 AM
HLG
11-22-1999 09:59 AM
