Blatant request for an answer on Denso or Bosch plugs..thx
I ask again...What is the benefit of high-grade spark plugs and at what stage (chip, exaust, etc.) will there be a realized gain? What will it do for me?
Thanks,
gigaenvy<ul><li><a href="https://forums.audiworld.com/s4/msgs/830075.phtml">Previous post on spark plugs</a></li></ul>
Thanks,
This is from Denso's website
Q. Why are there different heat ranges? Which one should I use?
A. Part of your spark plug's responsibilities, in addition to firing a spark, is to remove heat from the combustion chamber. This is accomplished by channeling the heat through the insulator material and metal housing. From there, the heat is transferred to the cylinder head where the engine cooling system can go to work. A spark plug's heat range is its ability to dissipate heat. The "colder" the plug, the more heat it can channel out of the combustion chamber. In a performance application, colder heat ranges may be necessary to handle the extreme temperatures brought on by higher compression ratios, forced induction, and high RPM's. While "Colder" plugs may seem to be the way to go, please remember that the spark plug must achieve its "self-cleaning" temperature where it can burn off fuel and carbon deposits. Otherwise, the plug could "foul out" where it is prone to misfiring and poor acceleration. A plug that is too "hot" can overheat, also causing power loss, detonation, pre-ignition, and possible engine damage. A good, general rule of thumb is to start with the factory recommended heat range. For every 75 to 100 hp you add to your engine, you may go to the next colder step.<ul><li><a href="http://www.densoiridium.com/faq.asp">http://www.densoiridium.com/faq.asp</a</li></ul>
RSA427
08-08-2005 11:10 AM
