which blocks should I log to fully characterize my current fueling setups?
for resolution's sake, it would be great if i only had to log 2 blocks at any one time.
im thinking injector duty cycle and a block that has O2 voltages. any other parameters i should log?
Those are probably the only ones you need.
If you have access to a wideband datalogger, you can drop out the O2 voltages and get more accurate data.
O2/AFR is really the most important. If you are upgrading injectors, the duty cycle/pulse width data is obviously going to change, so its not that relevant.
-Dave Pramanik
-Dave Pramanik
i am upgrading my injectors, but i want to get a baseline...
im doing the ol' larger injectors & lower fuel pressure "equivalent" setup.
so i want to be able to compare and contrast the two setups.
sieben
05-01-2008 05:19 PM
big_anthoiny
10-10-2007 01:25 PM
B5QShip
20
08-01-2005 09:33 AM
shwndh
03-24-2005 08:30 AM
mmart6545
08-18-2004 11:15 AM
