Boost on gauge, but Zero boost in logs
2000 TIP b-box /w APR v5 Stg2+ code.
Noticed car was running and building boost slow (0-100 in 16s). No leaks found after PT. Swapped 710b for 710n, and i got back the InstaBoost tm. But still no power. I ran ECUx (121 prop file) for the first time and I got back a flat line for actual boost.
Signs and buddies advice point to N75. or maybe wastegate lines? Any other suggestions?
<a href="http://mcostello.fusioncentral.com/logs/">Logs are here</a>
thanks
I put in brand new DVs and have done a pressure test /w 17psi. No probs there.
Car does not act like it is getting much if any boost, slow to 100 and no boost kick.
VAG shows no engine codes.
