Boost problem I think....Help!!
I have a stock 2000 S4, and recently it doesn't feel as strong as it used to. Occasionally second gear is a little late the with surging power like it used to.
Is there a way to check to see if my turbos are boosting properly? I dont have boost guage. Could BP valves be the answer? Should i invest in some aftermarket ones. Thanks.
sounds like what i had...
took it in for my 32k service and told them it felt like it was hesitating and surging. the dealer said that both BPVs were failing to hold vacuum and they replaced both of them. car feels MUCH better now.
my only worry is what this may have done to the turbos....
turbo fear....
if the BPVs are failing to hold the boost then the turbos are going to have to work harder to make the requested boost. so in a way it's like running with a chip (makes the turbos work harder) and according to Audi that will kill your turbos.
also, when we did the blown turbo poll awhile back it seemed like boost leaks (TBB, BPVs, f-hose,....) was a common condition prior to turbo melt down.
we'll see....
we'll see....
Re: Boost problem I think....Help!!
could be loose charge pressure hose clamps,vacuum leaks,air leaks,old style injectors,bad maf[or one on way out],faulty by-pass valves.if a by-pass valve is going bad or bad,you should hear a loud hissing noise in front of the motor and you might even hear one vibrating.new style injectors have pink tops[old style is gray].would need more info to help better
