CEL came on...VAG results
2 Faults Found:
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-10 - - - Intermittent
I did a search on both of them and I couldn't get a very good answer for 16825. I only found that it could have something to do with the N75 valve or purge valve. For 16826 I found that it could be a loose gas cap (always click it 3 times) or a bad evap line by the spare wheel.
The CEL has come on and went away and this is the third time it has come on. I cleared them but I'm pretty sure they will come back again. If anyone could post any additional information on these two codes, I'd really appreciate it. Also, is this a thing that I should go to the dealer for? I still have my used certified warranty.
What mods do you have? I had an EVAP leak CEL after I adjusted my...
Milltek 3" cat-back (before I sold it). Turned out that the exhaust burned a hole through the EVAP recirc line. If you have an aftermarket exhaust I'd check that line.
kpatz
15
11-26-2017 05:13 PM
M4NB00B5
20
01-26-2012 05:50 PM
rd350
A4 (B7 Platform) Discussion
10-11-2010 08:45 AM
FoKai
06-06-2004 10:57 PM
