Cheap source for Hazet tools?
<center><img src="http://www.hazet.de/prod_db/031/031030ba.jpg"></center><p>I need a Hazet tool. Anyone know of a place that sells them in the USA at a good discount???
Thanx.
Stephen<ul><li><a href="http://www.hazet.de/eng/katalog/suche_3.asp?F=779-1&H=100&U=210">Universal Ball Joint Puller</a></li></ul>
Thanx.
why not www.drivewerks.com ... 13$
<ul><li><a href="http://www.drivewerks.com/catalog/shopcart/TOOL/POR_TOOL_CAT500_pg43.htm#4">http://www.drivewerks.com/catalog/shopcart/TOOL/POR_TOOL_CAT500_pg43.htm#4</a</li></ul>
Have you used it though???
The one I need has to go over the early 2000 wheel bearing carriers (which are aluminium and therefore larger) and it has to hold the sleeve down (so the width of the fingers is critical) and it has to be flat at the blades.
Stephen
Stephen
i haven't used mine yet ..but i will try it (i ment to never did)
and i will let you know , take some pics too .
if you need it i can mail it to you and try it (since you seem to need one badly).
email me and let me know .
If it does fit properly then it would be a good solution and i will take you up on your offer
<center><img src="http://gallery.rennlist.com/albums/albuq92/AudiS4_2788a.sized.jpg"></center><p>Or else buy a cheapo one similar. I'm also worried a little about the pressure this things is going to need to apply. Hate for it to explode on me.
I'm really sick of this problem. I've been ignoring it for a while and working on other parts of the car. Now I really need to get it done. :-/
Thanx!
Stephen
Thanx!
Stephen
aluminumpork
04-29-2007 04:40 PM
Speedy72t
01-20-2004 10:38 AM
