Check engine light- 16826 (P0442)
16826 (P0442) Evaporative Emission Control System Leak Detected (small Leak)
INTERMITTENT
OK, so here is what happened...I replaced my Evap Purge Valve yesterday...and cleared my code...then on a little drive...the check engine came on again with this code above...
Should I go check the gas cap...clean it with a rag...and then re-clear the codes?
Thanks for the help guys!
INTERMITTENT
I will check it, thanks for the info....
So the Evap line is close to the Exhaust-which I do have aftermarket...could it be burned?
Thanks for the info!
Clint
Clint
James P.
07-29-2006 08:43 PM
cjk
11-22-2004 10:54 AM
steveinhisroom
06-01-2002 10:02 AM
Brad Bilut
01-30-2000 05:21 AM
