coolant light
Old Nov 12, 2007 | 12:49 PM
NAUDI4's Avatar
Member
Default coolant light
i am stumped on this problem. i have a 2000 s4 with a apr chip. after about a month or so my coolant light started flashing. my coolant level is fine, i replaced a coolant sensor with a new green top sensor, and i still have the flashing light. any help would be awesome. thanks zac
Old Nov 12, 2007 | 12:54 PM
Nigel (no more S4)'s Avatar
check the sensor on the bottom of the reservoir
Old Nov 12, 2007 | 12:56 PM
S4_Cinci (I S'edTFA)'s Avatar
Member
Remove the 3 screws and turn over the expansion tank. Either a loose connection or bad connector.
Old Nov 12, 2007 | 12:57 PM
reisumotorsports's Avatar
New Member
Default Re: coolant light
Your green top coolant temp.sensor is not the same as the coolant level sensor.Check the connector under the expansion tank,make sure that it's pluged in.
Old Nov 12, 2007 | 02:07 PM
NAUDI4's Avatar
Member
my sensor is fine and plugged in. is there anything else that can go bad for this reason?
Old Nov 12, 2007 | 02:23 PM
NAUDI4's Avatar
Member
after 5 secs of the car running the coolant light comes on every time. so im very stumped on this
Old Nov 12, 2007 | 02:41 PM
The_Jerbel (Jordan)'s Avatar
Junior Member
Or a broken wire somewhere
Old Nov 12, 2007 | 04:38 PM
Member
Default Cue the broken wire answer. Just because the connector is attached, doesn't mean current is getting
to the proper wire. Unplug the connector at the expansion tank, get a short piece of wire, bend it into a "U" shpae and connect it to both terminals on the connector. Start the car and if this cures the warning, you have a defective sensor or the wires aren't making contact. This ain't rocket science - the answer should be pretty simple, hopefully (unless you have a break in the wiring harness somewhere).
Old Nov 12, 2007 | 07:45 PM
Junior Member
Or the wires close to the connector are corroded and there is a break. Hopefully not a harness issue
Rune Korneliussen
Apr 16, 2013 01:04 PM
smirking
Feb 15, 2008 07:22 PM
TCimino
Jun 26, 2005 06:27 AM
white90+hibredS4
Apr 22, 2004 03:52 PM
Quattrould
Feb 17, 2004 02:21 PM
