Dealer says I need brakes: Fronts - 2mm, Rears - 5mm. Questions...
They say the brake light will turn on at 1mm.
What exactly are they measuring? mm's left till they need to be replaced?
What are the specs, total thickness, for brake replacement? I want to put my micrometer on them myself...
TIA.
TIA.
sounds like they are measuing pad material remaining.
its not hard to look and see how much pad is left. its better to replace pads before you start grinding the rotor with the backing plate.
