Did I miss something? What is the basis behind the latest Forge Valve fiasco? Can someone enlighten
the whole AW about <i>problems</i> they're having with the Forge's and why they <i>specifically</i> think that <i>IT IS</i> in fact the Forge's that failed?
...now <i>reconsidering</i> the Bailey's pending your input....
<a href="https://forums.audiworld.com/s4/msgs/301841.phtml">Here's a link to sequel #2 of my inquiry about the Forge's</a>
TIA!
TIA!
This post *may just be* the most viewed today but never replied on...some guys dont have the
nerve to comment or is it that maybe the fiasco is an isolated case and therefore is not a big deal????
just read the two main posts on the subject today; i think that should explain it...
...there have been intermittent posts for months of "increased lag after installing Forge valves?" The R knows his don't work. There's not that much that could be causing near complete lack of boost at low RPMs but fix itself by high RPMs except for a valve that's not functioning properly other than an electronics problem.
I have NO idea..I've been running the Forge's for 10K miles with no surging or boost lag
I pulled them out at 7K miles to inspect them
and they looked brand new, with no "sticking"
and there was the original amount of lube still present
I'm not planning on getting rid of mine any time soon
only thing that I can think of is that someone has a Faulty vac pump
that isn't really relaesing when they test it
or some Forge valves have too tight a fit between the piston and the O-rings
I've helped installed about a half-dozen pair for friends
and never experience the "stuck half-closed" problem
seems possible
but whenevr I buy a hand assembled part I always check it before installing it
if I have a questionable one I'll send it back for a replacement
and ask that it's checked before it's sent to me
and I'll check that one too
but it doesn't spund liek everyone is having the issue
so it may be something simple
I Wonder if it is related to a tolerance issue with the plastic piston
I would expect the plastic piston expands due to the heat in the engine bay. If the fit is too tight then this could explain why they hang up. I've got quite a bit of machining (lathe) experience and I can tell you it only takes a few thousands of an inch to make the difference between a smooth slide and something jamming up. Alternatively, if the fit is too loose then the piston may jam because it does not run parallel in the bore. This is especially true when using O-rings to make the seal. Just a theory.
