Doing my timing belt and cam seals a few more questions! (tons of pics)
First some pics that maybe you guys can shed some light one what is going on.
First i have oil every where but on this pic the oil is on the bottom of the exhaust manifold but not on the manifold, so is the bottom not hot enought to burn the oil?
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1602.jpg">
I should def change the water pump uhm!?
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1621.jpg">
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1620.jpg">
Ths cams look good.
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1608.jpg">
Looks like it was clean recently but still leaking oil every where. Gasket also looked good but still leaks.
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1590.jpg">
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1593.jpg">
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1597.jpg">
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1596.jpg">
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1592.jpg">
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1591.jpg">
Why are the cam seals diff? One(pass) looks like metal silver seal an its not leaking while the driver side is the orange rubber one and it is leaking. I suppose past owner used a aftermarket seal?
metal
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1622.jpg">
rubber
<img src="http://i101.photobucket.com/albums/m57/hdias4/s4tb/DSC_1625.jpg">
Ths cams look good.
metal
rubber
i have a set of seals i can look at my house when i get back in a few hours if you have not
installed them by then
the only picture of a seal on my website
<a href="http://enformulation.com/vag/s4/index.php?img=/turboswap/0013.jpg">http://enformulation.com/vag/s4/index.php?img=/turboswap/0013.jpg</a>
