Door latch adjustment......
What type of tool (and where can I get it) can be used to adjust the door latch on door frame? It's held in place by two star-type bolts. I'm trying to make the doors close tighter to eliminate the creaking I'm hearing from ALL the doors (I tried silicone, grease, etc. but it only lasted a few weeks). TIA
Adjusting the striker plate probably won't solve your creaking.
Tracking noises and solving them is a painstaking ordeal that many have given up on.
I took a look at that bolt you are referring to. It's not a torx bolt. It does have a star pattern, but it has 2.5 times as many ridges in it as a torx bolt. Hmmm, you might be able to talk your dealer into letting you borrow the correct tool for a few minutes?
ather
11-10-2013 04:53 PM
kingfishgrapejam
02-01-2008 06:28 AM
carbonLORD
03-21-2003 08:44 PM
