For a dyno test, where do should the straps be attached to? Also weight to use? TIA
Guest
Posts: n/a
tow hooks in the front and back. You can also go to the sway bars as a secondary tie down spot
But the primary should be TWO PER tow hook. Make sure they are angled away from each other (at least 90degrees is good). This helps with stability. One would think the Dyno operator would have this down by now
Also, It helps to have the belly pan off the front if you decide to use the sway bars.
leosphere
01-03-2006 06:23 AM
stressedjawa
A4 (B7 Platform) Discussion
22
09-02-2005 08:38 AM
audibum
24
03-11-2004 06:04 PM
