E-code question..
E-code question..
I tried to adjust my headlight, but seem like the thing is broken or so. I had this headlight since April. I haven't driving the car since then. I finally got a chance to adjust, but the passenger side would go up nor down. Any suggestion?
same thing happened to me. i adjusted them, and the autolevel feature stopped working. i took the
car to the dealer and i believe they did something with VAGCOM to solve the problem. But, i dont mess with mechanical adjustment anymore. good luck!
Re: E-code question..
if you try to adjust them while they are active they will set a code and you will be in a world of hurt with out a scanner. If you have VAG or access to a 5052 you need to go in to address 55 and clear any codes. Then to adjust them you go to basic settings 1 and wait until it says adjust, then you can adjust them. Once you have adjusted them go to basic settings 2 and when it says "position lernt" you will be in busniss, but without VAG or a 5051 or 5052 you are screwed. Good luck.
tj19855
09-02-2006 12:20 PM
exS4||wp0ZZZ
07-23-2006 11:00 AM
AmuletReed
12-04-2003 02:29 PM
