Engine Pull debate - With or Without subframe
Old May 13, 2009 | 07:16 PM
TheSkinFox's Avatar
Default Engine Pull debate - With or Without subframe
I have had my car sitting dormant in the garage for months. I pulled the engine last fall, went on vacation and never finished it because it was too cold. Well now things are warming up and I just installed a maxjax lift.
I pulled the engine with out the subframe, and will most likey put it back with out dropping the sub frame. But I'm curious for next time: now that I have the lift i'm wondering if it's be easier to drop the sub frame with the engine? I've done some searching on the forms I know this has been discussed before, but apparently my search kung fu sucks because I can't come up with the right combination of key words to find something. If dropping the sub frame makes a lot more sense, think it would make sense for me to drop it anyways and reinstall the engine from the bottm?
Old May 13, 2009 | 07:27 PM
complacentsee's Avatar
I've read dropping it is easier, but you just gotta be very careful of the alignment.
Old May 14, 2009 | 08:43 AM
RolledMySTi's Avatar
I've pulled the motor 4 times now and have never dropped the subframe. It's not necessary and is easy to do the regular way. Plus dropping the subframe means you will have to get an alignment when you are done.
Old May 14, 2009 | 03:48 PM
davenew's Avatar
Yea, I don't drop the subframe either..
Old May 14, 2009 | 04:38 PM
TheSkinFox's Avatar
I was hoping with the lift dropping the sub frame might be easier, but guess not.
polksey
Aug 29, 2022 10:50 AM
scoutmasterdave
A4 (B9 Platform) Discussion
May 5, 2017 09:41 AM
baard
Q5/SQ5 MKI (8R) Discussion
27
Jan 5, 2012 03:16 PM
audithepeanut
Jun 15, 2008 07:42 AM
Jason Sowers(rs6's)
Dec 27, 2006 09:03 AM
