Getting redline MT-90 for tranny smoothness. Any DIY links to replace tranny fluid?
pretty simple, just remove the fill plug, then the drain plug...
the drain out the old fluid. Re-install drain plug, fill tranny until fluid drips out. Re-install fill plug. Finished.
Note you want to make ceratin you can get the fill plug out before your remove the drain plug. Also your car should be level for proper fill amount, unless you measure.
If you search the A4 forum there is a writeup. S4s just take more fluid and have a different size hex bolt plug but the principles are the same. Might as well do your rear diff at the same time.
There are 2 drain plugs...I removed both, but maybe it doesn't matter.
<img src="http://www.funkadelic.org/albums/driveline_fluids/aac.jpg">
<img src="http://www.funkadelic.org/albums/driveline_fluids/aad.jpg">
