Got a CEL after dealer replaced my after run coolant pump...(More inside)
So they replaced my pump on Monday and about 5 miles away from the dealer the CEL comes on. I call them on Tueday morning and they say bring it back and they'll look at it. So I take it back and they say it was a loose wire on the cam position sensor so they reconnected it and everything should be all good. Well, this morning my CEL comes back again so now it's back at the dealer. I also noticed that there is a very high pitched whine coming from the engine bay after I start the car. It sounds similar to the noise that you hear when you do the throttle body adaptation after replacing your ECU. Anybody know what could be going on here? I think the tech forgot to connect or put back some parts when they took it apart to do the pump replacement.
The elect. coolant pump makes a high pitched whine when it runs...
Not sure what they could have done that would cause the pump to run continuously (which might be the case since you claim to hear the whine as soon as you start the car).
I don't know, and I'm not a psychic, I don't know what the CEL is for.
I'm just explaining what that whining sound might be. Get the car scanned with vag.com to see what the code is.
jimdoo
06-16-2008 09:28 AM
TTransport
08-27-2006 11:51 AM
Oettinger_A4
12-11-2004 11:06 PM
