Got my S4 Tip - mirror and radio questions
Guest
Posts: n/a
Picked up my S4 Tiptronic a few weeks ago... WOW what an amazing car! There are two little things bugging me that maybe someone out there has a solution to:
1) is there a way to turn off the engine and keep the radio playing, short of rotating the key all the way back to a full power on position?
2) is there a way to disable the auto-dimming of the side mirrors? I don't mind the center mirror dimming but the sides seem too dark to me.
Thanks,
-james
Thanks,
-james
Guest
Posts: n/a
re mirrors
I think the three mirrors all dim together from the one sensor on the rearview. To disable this feature just put a little piece of black tape over the sensor on the lower edge of the rearview mirror. It's the little hole on the lower edge of the mirror housing, and this is what reads the lighting situation outside and behind you, so as to determine whether or not to dim the mirrors.
You need to do this in the daylight, when the mirrors are in the normal (non-dimmed) position.
To re-enable just remove the tape.
bear1906
12-01-2004 01:29 PM
Rancor
10-21-2003 07:30 PM
