Headlight wiring source?
I chased down a high beam issue and found that the mini/sub wiring harness (8-Pin D-Plug to 6-Pin Valeo Ballast Connector, H7 Highbeam Connector, 3-Pin Headlight Level Motor Connector) behind the high beam port is essentially rotting due to heat and age. The insulation on the H7 connector wires was cracked or missing along the length of the wires.
I've tried several searches to locate a replacement harness but not seeing anything out there. ECS has replacement Valeo OEM headlight housings, which is tempting anyway, but as far as I can tell they do not include the wiring harness inside the housing.
Has anyone found a source for these? Or suitable connectors so that I could build one myself?
thanks in advance!
Jeff
2001 S4 Avant
thanks in advance!
Jeff
2001 S4 Avant
nick@ion-e.com
A4 (B8 Platform) Discussion
03-28-2020 09:18 PM
nick@ion-e.com
Want To Buy - Archive (NO NEW POSTS HERE)
02-27-2015 07:01 PM
AudiOC
04-21-2003 05:51 PM
Audicted2quattro
08-18-2002 04:33 PM
