help removing center rear console?????
is there a trick to this? it looks as if the armrest should just pull up to remove...manual doesn't indicate any bolt attachments.
can't get the trim for the brake lever off either. i get it loose but then it is obstructed by the console cover, which is what i'm really trying to remove.
f-dang!
f-dang!
Re: help removing center rear console?????
You don't need to take the armrest off. There are 12mm (if I remember correctly) bolts under the rear ashtray assembly and 2 8mm by the front seats that are hidden under the caps.
UnoDosTurbosQuattro
Audi A3 / S3 / RS 3
03-12-2009 05:04 PM
Avants
07-11-2005 03:51 AM
