Help: Removing door trim panel
Avant should be simliar to the sedan...
There are two screws at the edge of the door frame. Near the base of the window. Remove these two screws and the entire door panel can be lifted up and out.
No. They are the same, but you've missed a step....
One additional screw in grabhandle, remove grabhandle sleeve. Then, two screws (brass-headed) screwed into the door panel at 90 degrees, under grabhandle sleeve, anchor the grabhandle/trim panel to the door. Remove them, then:
Lift up/out.
Both the sedan and avant are like this.
Lift up/out.
FASTAXI
9
02-17-2009 07:01 PM
slimcubby
06-11-2005 07:45 PM
Mark - Steve's bro'
Audi 100 / A6 (C4 Platform)
9
11-24-2003 05:53 AM
odj
10-04-2001 04:29 PM
