HELP with tranny!!! No reverse no 5th and 6th gears...Please reply ASAP...
Hi all audi entusiasts, I had my car for about 8 months and BUM...out of nowhere....reverse is not shifting in, 5th and 6th gears....all other gears are fine...some grinding in 4th when I try to get in 5th and need to go back into 4th....REVERSE can be engaged in with some little effort when car is not warmed up...IF i get into the car and start and enage into Reverse - No probles at all, but after driving for 5-10min I cannot shift in Reverse anymore...same if car is not driven but engine is running for 5-10min. Please let me know what is up...before I do replace the whole tranny...I did try linkage issue, no change...if you have any other suggesions please reply...my car is '01 S4 with 42k ml...very clean and never driven hard, my warranty just ended before I realised that I should off extend it...now it is too late to go to dealer...but even if I will have to go to STEALER (dealer) I want to know what is wrong with tranny from you guys(girls)...also if you know some good shops or mechanics for audis in tristae (NJ, PA, DE) let me know their info...THANKS to you off all - my only reliable source for info and advise in my Audi needs. Reply or write me....my email PhilyZ@gmail.com
So what needs to be done to my tranny...please be more specific guys....
i will appreciate if you can direct me to some good write ups with pics on any related info...thanks....
By using the "search forums" tab at the top center of your screen.......
you can type in several different things to find what you need. I used "S4 shifter adjustment" and found toyguy's install page. It should give you enough guidance to take care of it. GOod luck!<ul><li><a href="http://toyguy.o-f.com/ssi.html">http://toyguy.o-f.com/ssi.html</a></li></ul>
UndergroundRaver
06-22-2004 07:16 AM
2low4snow
14
04-09-2004 08:36 AM
B. Lane
13
02-02-2002 07:06 AM
imaudi5
Misc. Models Discussion
10-24-2000 03:15 PM
