How do adjust my head lights?
No, you do NOT adjust your headlights with the VAG tool.
you use the VAG to normalize, or "learn", the resting position of the car with a driver in the seat. The headlights will set at middle of thier computer controlled range after this.
Then, you adjust the beams with the usual mechanical screws.
That way, the headlamp position can be automatically trimmed depending on loading in the car.
there is a screw near the headlights someplace... its right on top........
i had to do it a while ago, you just turn it a certian direction and it will lower or raise depending on which way you turn it. i thought you were able to do it with the vag also.
Good idea to relearn the neutral position anytime you mess with the suspension.
Even if you lowered the car equally level, it's probable that the new suspension is stiffer, and a driver seated in it will not affect the level as much.
DanosS4
12-03-2007 06:36 AM
AreenS4
10-26-2006 08:33 PM
