How does an RS4 get from
Guest
Posts: n/a
265 horse to 380? Bigger Turbos? Intercollers? what? Obviosly it makes more boost, how much more? Is it as reliable as an S car? I am awaiting an S car and would love to get 380 out of it! Waranty issues are none, can this be done in a reliable fashion for less than the cost of a small condo? I heard a chip takes you to 320...at what kind of boost levels is this achieved? Is it out of the ball park to assume that a full exhaust including a high-flow rezzy would get you to 340?
If I could build an S4 Avant that goes 105+ in the quarter I would be in heaven!
Damon
A4 Avant QM with all the trimmings.
Damon
Guest
Posts: n/a
Try reading down the page--(more)
probably 2 bigger turbos and engine management, and some minor stuff. The cylinder heads, however, are designed/built by cosworth, which is only of note because the s4 heads might not be strong enough???
Anyway, read lower down the forum page and you will see a discussion about this.
In addition, 225's seem to be the widest tire that can fit on the S4, another topic which has been here frequently.
-Rob
00 S4 (HA status) *almost* cancelled order
-Rob
Guest
Posts: n/a
Re: Try reading down the page--(more)
I have already had a 245/35/18 on my A4 Avant with NO scraping so I know the 225 comment is wrong. So like I guess someone should read the entire forum before posting a question or they have to listen to your dribble, huh? If that was the case there would be very little to post here. Between the archives, 9 pages of forums and 12 different forums, I'm sure every issue you could ever bring up has been beat to death here. Thanks for the cylinder head info...lighten up a bit.
D
D
SantorinSteve
09-21-2002 10:03 PM
Driver With No Name
05-01-2001 03:28 PM
wondering
01-17-2000 04:31 AM
loreon
14
08-25-1999 09:15 PM
