How hard is it to install the APR Bi-pipe?
Nearly impossible.. Take it to a mechanic..4 hr labor.. well worth it imo
Not that hard.. Of course i did install it with the whole front of the car off. So what do i know ?? : P
PIA tight fit and you can screw it up if not careful/experienced
Be sure to lube the o-rings and inside of the Bi-Pipes' mating surface with a dab of motor oil before installing. Otherwise you'll damage the o-rings and it will either leak of leave bits of oring rubber dangling in the TB.
I don't know about some of these opinions but it takes me 30 min at most to pull off and put on.
With the front bumper on. Just did it a few months ago when I changed my PS pump. It really is not hard if you take your time and don't drop anything.
The first time it took me 1 hr because I dropped some bolts down by the Int. Mani.
