Installing Schroth harness
So, I managed to get all but one of the points installed for the harness.
How do I get the point attached to the right of the drivers seat installed? (The side next to the hand brake, center of the car, etc)
I got the seat out of the car (not an easy task) but I couldn't figure out how to get the point installed anywhere on that side.
Re: Installing Schroth harness
You've got to use the brass colored bolt that anchors the stock buckle on the right side. It's near the truck that fits into the rail (slide), at the very bottom rear of the seat. If you can't get your wrench onto the bolt, use some channel-lock pliers and rotate the truck so that the bolt is accessible.
Hope this helps. This is truly the hardest part of the job.
Corey S
00 Nogaro S4
Corey S
00 Nogaro S4
Which side of the standard buckle did you install it on?
I see in the Schroth manual where it shows a typical Audi/VW install and it shows it on the inside of the buckle, seems kinda tight there. Doesn't look like the buckle would be able to move much
AudiWorld Expert
Why do you think we do the install as a group...
You shoulda asked...we coulda helped. Although Corey is
the champ at that specific part of the install. All you gotta do
is feed him.
Steve S.
00 S4
is feed him.
Steve S.
00 S4
Heh, I realized that after I got the chair out
My roommate, who offered to help, was busy today so I figured I'd give it a whirl.
The first time is always the hardest, now that I've done it once, the second time won't be as hard
BrokenRocket
13
03-07-2007 02:12 PM
j31izzle
03-04-2006 07:18 PM
