K04's and stock chip. Should I being seeing more that 10psi?
I've just did a few 3rd gear pulls and noticed I was getting ~11-12psi. Ended up shutting it down around 5K rpms to prevent any damage. Did a few more runs to 5K with same results. Is this normal? I thought stock boost was around 8-9psi.
should I break out the lemmingwinks and add a bit of fuel?
or keep it at the current level? Limmingwinks work with A-boxes right? can't really remember if there was any issues. Also could the 90-100 degree heat be a cause of why the boost is a bit higher?
