Launching debate
Old 11-15-2002, 07:35 PM
Junior Member
S4Tune's Avatar
Default Launching debate
Ok, we have a problem. My friend says I don't launch the car right. I just rev to 3-4 grand and drop the clutch. Stage 2+, chirps the tires in first, takes off like a bat outta hell, no problems there. He says I need to feather the clutch out, and I'll never get a 1.8 60ft. I bet him a hundred bucks that I can get it next time we head to the track. He says I'm dropping the nose of the car in 1st...I say he's crazy. Can you drop the nose by dropping the clutch at full throttle?
Old 11-15-2002, 07:38 PM
New Member
S4Senna's Avatar
Default Re: feather the clutch.....not with turbos.....3-4 grand is perfect.
or 5 if you have a stronger clutch...
Old 11-15-2002, 07:40 PM
AudiWorld Expert
Milpitas2.7T's Avatar
Default YEP.. He is absolutely right, hold the r's at 3K and before the light goes start giving it throttle
Gently, you want to be giving it throttle as you are letting out of the clutch.. Dropping it at that low RPM, you will absolutely drop your nose.
But you don't want to drop the hammer either, maybe from 3K to 3750 or so..
He is absolutely right and I have 60ft's to prove it..
Old 11-15-2002, 07:47 PM
ChaoticS4's Avatar
so walk me through this tory... I want to do burnouts!!!
Old 11-15-2002, 07:59 PM
AudiWorld Expert
Default Oh sorry my friend.. No burnouts for me, no clutch smell either just solid launches.
MAdman is your man for burnouts.. Not my thing, if I wanted burnouts I would get a Camaro
Tory
Old 11-15-2002, 08:05 PM
Elder Member
No More B5 S4's Avatar
Default I don't just do burn outs...
...I play on the street, even with 19" Sportecs:<ul><li><a href="http://www.doodmonkeyradio.com/~s4madman/audifiles/nicelaunch-2.mpg">http://www.doodmonkeyradio.com/~s4madman/audifiles/nicelaunch-2.mpg</a</li></ul>
Old 11-15-2002, 08:08 PM
Junior Member
S4Tune's Avatar
Default Wait wait wait...
Run this by me again. I punch the gas 100% right before I drop the clutch to put load on the engine (so the BPVs open and the turbos spool) at about 3k, then when it's nearing 3500, 4k, I sidestep the clutch and BAM. All this about the light throttle, slow feathering of clutch...I don't see how this helps speed. I think I'm missing something here...what is it?
Old 11-15-2002, 08:16 PM
M3KILR's Avatar
Default lets the clutch engage closer so it grabs quicker the more slip the more time your losing........
if you drop the clutch it will just slip or worse smoke. On the otherhand if you sidestep it it will grab quicker and more frequently. Also helps keep the clutch in good health.
Old 11-15-2002, 08:17 PM
Junior Member
S4Tune's Avatar
Sidestepping makes the clutch grab QUICKER? that confuses me...
Old 11-15-2002, 08:19 PM
AudiWorld Expert
I love that video!! ))) you are a MADMAN sir
Quick Reply: Launching debate
