Is this a legit OBD II cable?
<center><img src="http://www.obd2cables.com/images/products/obdii_cable.jpg"></center><p>This site (Scantool.net) has 2 different cables; Type B and Type C.
Has anyone bought a cable from this site? Is there any way to make sure the cable will work with VAG-com?
TYPE B:
http://www.obd2cables.com/products/obdii_cable_type_b.htm</url>
TYPE C: - click link
Thanks. Btw, I found it odd that "scantool.net and "obd2cables.com" were the exact same.<ul><li><a href="http://www.obd2cables.com/products/obdii_cable.htm">http://www.obd2cables.com/products/obdii_cable.htm</a</li></ul>
TYPE B:
Not without a separate interface
If you read the description, it is designed to connect to an interface, NOT to the serial port of your computer. They sell appropriate interfaces on the site, and there is a link on the page to plans for a homemade interface.
The OBD-II port uses different voltage levels than the serial port on your computer. The interface uses optoisolators to electrically separate the computer from the car.
audiqv8
02-12-2005 09:19 AM
DAN
12-06-1998 06:54 PM
