Logged an MTM box tonight (w/mods)...take a look, tell me what you think.
Stats:
2001.5 M-box S4
Mods: MTM ECU, MTM downpipes, MTM exhaust, Forge DVs
Look below and tell me what you think. Only thing that concerns me is the boost and the relatively lateness in full boost. Max boost, 1.17 BAR at 4080 RPMs. How does the rest look?
Boost
<img src="http://wuzup.com/wes/pics/logs/boost.gif">
Timing
<img src="http://wuzup.com/wes/pics/logs/timing.gif">
MAF
<img src="http://wuzup.com/wes/pics/logs/maf.gif">
The logged info:
<a href="http://wuzup.com/wes/pics/logs/mtmlog.htm">Actual Log</a>
2001.5 M-box S4
Boost
Timing
MAF
The logged info:
It all depends when you start flooring it. You will always see requested come on before actual.....
The boost looks fine IMO. Based on your post of 93 octane and 42 degrees, I would think you would have a touch better timing. Either way, not bad at all. Just go out and enjoy
Info On Car...
Well it was my car and Wes was nice enough to do the logging with his VAG and post it here.
the car is:
MTM Stage 3:
-MTM DP's
-MTM Catback
-MTM Chip
-K&N Filter
-Bosch Platin Plugs
-5bar FPR
and:
-Forge DVs
and other non-engine related stuff
01/10 Build M-Box 6spd
Before the Pull the car had been run hard with two other pulls and I had to show some moron in a Lincoln what was up :-). In this cold weather is a little heat soak still an issue?
Thanks,
Stephen
the car is:
MTM Stage 3:
-MTM DP's
-MTM Catback
-MTM Chip
-K&N Filter
-Bosch Platin Plugs
-5bar FPR
and:
-Forge DVs
Thanks,
Stephen
