lubro moly gear oil
http://www.blauparts.com/proddetail.asp?prod=LM+2048
also would it need this in each differential.....
http://www.blauparts.com/proddetail.asp?prod=LM+2019
please let me know asap which one and why i am looking to buy this week
Fully synthetic and GL4 and GL5 so it's safe to use in both applications.
Motul Gear 300
"become quieter thanks to the MoS2 Plating action of gear teeth."
Moly will not plate anything, it will burnish the surface. As an additive, I'm skeptical about it staying soluble in the gear lube at operating temperature and just precipitating out to the bottom before it can do any good. You'd be better off to burnish the gears with MoS2 powder and remove any residual material before assembly. However, there may already be a ceramic coating on the components to begin with to prevent galling in which case the moly may not do much of anything for you. Does anyone know if the gears already have a low friction surface treatment?
