Misfiring my balls off and need help please......
Old Jul 1, 2007 | 12:41 PM
Gray Bush's Avatar
Default Misfiring my ***** off and need help please......
So my cylinder 5 and 6 at idle misfire over 15 times per Vag Com interval of I believe a minute and half. Block 14 and 15 show the first 4 cylinders not mfing at all. 5 and six are over 20 sometimes as much as 35 and it stores three codes. Never a check engine light. I also noticed that block 2 shows the engine load at 15.8 to 16.5% during idle. When I turn on the Ac the engine load goes up to 24ish and my misfires decline dramaticly. To the point of maybe 3 to 4 per cycle and once again nothing on the first 4 cylinders.
I have swapped plugs, coil packs, ignition amps. I have no boots leak and no vacume leak. The car runs great and doesn't misfire at all during pulls. Plugs are torqued and are the bosch platins everybody talks about. They are torqued to 30nm per bentley.
The car is APR OTS stage III. I am starting to think that I may have bad valves! SWEET!
Old Jul 1, 2007 | 12:54 PM
lemieux@curbside's Avatar
Default use lemi and increase the idle load untill you see 20-21% ch2 (almost like with ac on)
for the hell of it .. swap the plugs on the ignition amps on top of the airbox.
last thing that u might do is swap injectors around they can be problematic too (yeah even rs4 parts can go bad)
Old Jul 1, 2007 | 01:17 PM
Gray Bush's Avatar
Default Will raising the engine load by itself cause any other issues.....
everything else you mentioned I have already done. Wouldn't a bad injector cause issues under load as well?
I have no issues under load.
Old Jul 1, 2007 | 02:09 PM
vegasS4's Avatar
Member
Default does apr have you change the green coolant temp sensor with their kit? Might want to ....
check that too
Old Jul 1, 2007 | 02:10 PM
Gray Bush's Avatar
Default Coolant temp sensor is changed. I would like to know what engine load
other apr ots stage iii kits see at idle.
Old Jul 2, 2007 | 03:45 AM
B5QShip | CFDQ's Avatar
Junior Member
you'll consume more gas on idle...
Old Jul 2, 2007 | 04:58 AM
Flyboy's Avatar
23, +/- ~2
gfirewalker
Audi allroad
9
Jun 23, 2012 04:08 PM
JohnnySweet
May 4, 2009 07:07 PM
Audi_kraut
Nov 10, 2007 09:39 PM
gonutz
Sep 21, 2006 05:02 PM
SuperGreg
Dec 4, 2003 10:54 AM
